Is there any in-between way to ride with a China girl motor> I find that at half acceleration the whole bike shudders so much, it only smooths out at high revs (flat out), also shudders a lot as you accelerate.
Thanks FR. Wouldnt even know where to start. This happened from the very first startup & run - since then Ive done about 20 trips up & down our little side street.Sounds like clutch chatter to me, you may have glazed the pads on a hard take off... have a look, if its not glazed try adjusting the clutch "IN" tighten the star nut two turns at a time, remember not to loose the tiny clutch locking screw.
FR
What kind of motor do you have, specifically the carb?Thanks. For a brand new motor, where do you get the specs of using '2 turns' for the star nut? Is that just a standard adjustment for all new motors?
You're welcome.Someone finally asked my question about whether you can use the motor & clutch (without pedals) to take off from a stop - thanks. I will pedal until I have enough momentum.
I have the NT carb.
How do I adjust it? I only see an idle speed screw (which I had to turn in as it didnt idle initially)
