DUAL PURPOSE pusher / rack mount
foundmydog
Hello all...
In the very early stages of building and designing right now, but it seems very doable with not much cost involved!
What I am in the process of making is a dual purpose power source which would power a small push trailer, and then be easily removed from the trailer and be used as a rack mount poser source.
The trailer, when used, would be attached to the rack mount by a 1/2" bolt serving as the trailer hitch. When the trailer is removed the throttle cable would be carried over with the engine to the rack mount, and the trailer easily removed!
The power source would be the infamous $89 TANAKA PF3300 running either way via a jackshaft and gearbox.
The gearing of the trailer with an 11" tire would be 16.20 to 1 which would top out at 22.2 miles per hour.
The gearing of the rack mount with 26" tire would be 20.00 to 1 which would top out at 42.5 miles per hour.
The engine and pillow block bearings for the jackshaft will be attached to a standard horizontal shaft engine mounting plate. This unit itself is what will be easily removed from the trailer and placed into a rack mount when wanted.
I will give detailed info through the course of the build and keep the thread updated.
My approach is to fully build the trailer first and create the "power unit".... then build the rack mount and reverse engineer a way to fit in the "power unit" and have it easily mount to it.
The rack mount will be along the lines of how a friction drive is mounted to a bicycle.
The "power unit" with attached jackshaft with need to be "re geared"... BUT if my math is correct, all would need to be done is reverse the 9 tooth and 15 tooth sprocket on the jackshaft.
All sprockets and chains will be most likely #410 pitch for ease of use...
Waiting for the sprockets and keyed shaft to come from Staton so I can make sure the sprocket fits under the engine before attaching the pillow block bearings
More to come when parts arrive
Ahhhh, still waiting on the Staton sprockets and keyed shaft to show up
A few quick pics of the trailer layout so far...
Made some progress this morning with the trailer build
* cut the metal cross bars to keep the trailer frame squared and to support the removable power unit
* mounted the horizontal engine plate to said cross bars and squared it up to the trailer frame rails
* mounted axle to frame rails with pillow block bearings and lined them up straight to the frame
In a holding pattern right now waiting for the Staton Inc parts to show up to be sure jackshaft sprockets will fit under the engine, and mount those pillow blocks for jackshaft to the engine plate
Rough measurements on the trailer right now are...
24" long x 11"wide x 17" height
Most likely this will be a theme bike and trailer, so thinking of semi enclosing the engine and wheel inside a covering.... need to factor in ventilation for this as engine is air cooled!
More to come when Staton parts finally show up!
Well... STATON INC parts showed up yesterday, missing the 15 tooth sprocket I ordered and it was zeroed out on the invoice sooooo guessing it was out of stock???
Would of been nice if he let me know before shipping it was out of stock so I could order the 14 or 16 tooth sprocket! ( thanks dave )
Progress on hold once again as I go back to STATON INC and order another sprocket for the jackshaft
Down but not out...
Logged onto the always in stock and reliable McMaster Carr and found a 15 tooth 5/8" bore sprocket for ~$12 or so
Should be here by Wednesday, so hopefully another update by Thursday
15 tooth sprocket is just shy of 3" in height.... this may wreak havoc with the jackshaft under the engine... more to come
Worked on her a little more today between football games...
McMaster Carr says the new 15 tooth is almost 3" in diameter... which is way to close to the engine on the jackshaft sitting under it
Moved the jackshaft right above the rear axle and tire and will most likely keep it there
This will allow me to slide the engine back about 2 inches whoch will make the trailer even smaller!
Off tomorrow.... so I should have an almost complete trailer MINUS one of the jackshaft sprockets which should show up here by wednesday
Drilled the final holes today in the engine cradle and trailer frame... painted all metal parts and waiting on them to dry to re-assemble everything again
Waiting on the 15 tooth sprocket for the jackshaft before I can line everything up... but will post pics later this evening if paint dries in time!
See attached pictures...
MUCH progress the last two days...
Jackshaft sprocket showed up the following day after being ordered from McMaster Carr
Trailer frame, rear axle, and jackshaft all lined up and bolted down into place
Drive chain sized up and installed from wheel to jackshaft sprocket and tightened
Chain sized up from gearbox to jackshaft BUT in need of a #41 master link before I can tighten chain and bolt engine down
Working on the front bracket which will attach to the bicycle... all done, just waiting for the paint to dry
YES... that is olive drab green! Going with an Army theme so main parts got painted!
TRAILER HITCH...
Not going to go with the typical tube running up and connecting onto the seat post as a trailer hitch.... have done that before and it works well.... but I think it ruins the look of what I am going for and not being able to use a rear rack at all
MY IDEA...
Using flat bar stock, 1/4" thick x 2" wide, I am going to bend it into a "U" shape and have the two ends attach to the dropouts of the bicycle... NOT the axle, but drill two holes maybe 3/8" into the back end of the dropouts and use grade 8 bolts and run them thru the dropouts and thru the flat bar and lock it down with nylon locking nuts just a hair loose as to create a pivot point for driveways or steep inclines
The center of the "U" flat bar will connect to angle iron which is run up vertical from the front of the trailer
Working on it right now and should have pictures to show by tomorrow...
More to come
I wanted to make an important suggestion for your jackshaft above the drive wheel. You need to add some more bracing to your current all-thread that holds your bearings above the wheel. All-thread is low grade steel, and bends easily. You need to run a couple pieces of the flat stock you've been using down to the frame to form a triangle on both sides. I'd also run one from one of the bearing mounting feet down to the frame on the other side.
Erich
Erich
Those are actually grade 5 full threaded bolts I am using, and not all thread
I knew about allthread being close to pot metal status and went for grade 5 hardware where needed
I will watch them for bending or snapping, but I think they will hold in place... only time will tell
Jus' as a FYI
While "all thread" is commonly available as coarse threaded, hot rolled, cold drawn, low carbon steel... in actuality it's offered in many thread pitches, grades & alloys *shrug*
wow this is really cool
do these builds work as efficiently as the other 2 types
I've personally built and ridden every type of MB you could think of... and I would have to say that a pusher is my favorite!
Gearing can easily be worked out to give you the speed or power you want... there is absolutely NO vibration in the bike itself from the engine... and being low to the ground and a few feet behind you makes for a VERY quiet ride!
My previous pusher was a 5 horse horizontal shaft engine which was extremely powerful... going for a smaller type pusher this time
Jus' as a FYI
All the local hardware stores around me only have the semi-pot metal version... where might one find grade 5 or grade 8 allthread???
Lost my #41 master link so I am waiting on a few to show up from McMaster Carr... should be here tomorrow
While waiting for the master links, I took another look at her and decided to make her smaller lengthwise... should work out to be right about 6" shorter in length
Trimmed down the horizontal engine plate and slid the engine closer to the back tire which pushed the engine back 2"
Decided to cut off the gas tank area that would of been between the front of the engine and the trailer hitch which gave me 4"
Waiting on the master link so I can tighten the chain from the engine to jackshaft and then cut down the front trailer frame rails by 6"
New measurements should be
18" long x 12" wide x 17" high
I am going to make a trailer frame cover out of 1/2" PVC pipe and fittings which will rest on top of the trailer frame and cover the whole unit
Will leave the front of the cover open to access pull start handle and for ventilation
Will run a tube from exhaust down and to the rear of the tire to get rid of the heat and fumes
The top of the trailer cover will be wood screwed to the PVC pipe for mounting a couple AMMO boxes to... remember it is an Army theme... one AMMO box will hide the gas tank, thinking a half gallon tank or so maybe
More to come
I suspect if you asked them if they had/could order different grades of threaded rod they'd be happy to help, but there is also always this: Google Product Search
w/keywords: all thread rod - which returns w/various grades and alloys, mild, galvanized, stainless, even titanium;
Amazon.com: Grade 2 Titanium Threaded Rod, ASTM B-348, #8-32, 36" Overall Length (Pack of 1): Industrial & Scientific
That is one Rube Goldberg looking build, how do you plan on attaching it to the bike?
FR
P.S. you were better when the dog was still lost.
