ok, I think I can do that. The plug does eventually turn black after a week of driving it.
And about removing the plug on a hot motor, I do usually wait a few mins before I remove the plug. It's still warm but not hot. Is this ok?
BTW just had someone ride along next to me to see what my top speed was and it was 35mph. I was like, "No way!" The top speed on my old build was only 25mph. I'm rather skinny, so that helps.
I'm 6'2" and only 170lb. I Never could gain wight and I eat like a horse too. But man 35mph thats fast for a bicycle. ****, if I put a smaller rear sprocket on, instead of the 44 tooth one, I might be able to get up to 45mph and would be able to leagle travel on the hwy. LOL
Edit:
LOL, can't say the H word. You know heaven or h***.
when I plug chopped a 70cc scooter I big bored from a 50cc I had no results either. Even on a website for that scooter no one ever posted plug chop pics but all had claimed to do them
maybe its the newer oil or fuel or the small size engine but im a big believer in driving it for a week to check
I went through 5 jet sizes, 8 plugs, all needle ranges and never got anything but white on my plug ceramic
even when everyone used the same jet for the same engine, same altitudes
even my 4 stroke fuel injected scooter I did a plug chop when it was stock fresh from the factory all white
when I big bored it, threw in larger fuel injector all white
added a fuel controller and purposely added more fuel all white
but waited a week and got the nice tan color and its stayed the same for over 4000 miles, on my scooter
So I would go with jetting until it bogs from being too rich then go down one set at a time
with drilling I guess maybe you can be more precise after soldering it back up if you kept track of the drills used in order
here is an example of my 2 stroke chops, note I was always told to look for the smoke ring deep in the ceramic for main jet chops
the normal ceramic you usually see is the lower jetting like the needle
See the tiny smoke ring under the threads I cut off but the tip has a touch of black
this jet was too rich
I ended up at 87 I believe they only went 80, 82, 85, 87, 90 so I didnt have too many to choose from
Stock was 80
this was after 2 weeks, note: it looks what is considered good
tan on the ceramic, hard to see
