Ok, I'm at a freakin, loss!
his196
Grubee GT2 48cc
SBP Ex. Chamber
Dax RT Carb
Boost
NGK Sparkplug
32:1
800 ft. elev.
Ok, that's the bike.
Here's the problem:
Lost power/spark.
Changed:
Brand new CDI, cut white wire completely, and all solders/grounds look good.
Not wet. Scuffed back-side of Magneto Frame/Ground.
Upgraded wire from CDI to Plug, wire correctly.
NGK Plug brand new.
Brand new magneto installed, and woodruff pin in place on magnet.
Seals good, no air leaks anywhere.
Checked on the gear side, pulled gear, gear in tact, no seal leak. Re-installed, nice n tight.
Wired correctly. No KILL switch attached, blue wire only!
ZERO spark!
HELP!
WTF?
Thanks.
PS: Bike ran great for about 350 miles prior to this.
Chris B.
no spark...put a volt meter on the coil wires and see if it swings at all....better yet see what ohms it has...infinity is a busted wire inside the coil.
Just because parts are new doesn't mean they are good. Like said, check magneto output. Check compression.
Compression good (finger in the sparkplug hole test).
Sucks and blows strong.
Don't have the tools for ohm testing yet.
Will pick up.
What type/range of meter should I get?
~Chris B.
a cheap 6 buck meter from HF is a good bet.
How do you know u have no spark? I remove the spark plug connector from the wire and insert the plug wire into a cooling fin. I then pedal/pop clutch so engine turns over and watch/listen for spark....I do this at dark so I can see it.
how are u testing spark??
Hey Drewd,
I'm testing for spark with plug out of jug, and laying on the fins, and ZERO.
I just did a complet OHM check and here are my results, compared to a recent post with suggested readings.
Thought?
See below:
Hey there, based upon a former post, I've included my results here on my 48cc GT 2, with ZERO spark, and would love your preliminary analysis. Thanks in advance for your time!
New CDI, new Magneto, New Spark plug, Upgraded cable. I CUT off the white wire connection completely ON the coil, although there's still a 'nub' to connect to for testing.
Woodruff key in place (superglue), Varnish/Contact points all scuffed.
Ok, so following your recent suggestions, here are my answers with my new Multimeter, step by step.
Use Low Ohm-Meter Scale About 200 Ohms
Magneto Coil
1) Check Ohms between BLACK wire and WHITE wire. Reading should be around 2 Ohms (3.3)
2) Check ohms between BLUE wire and WHITE wire. Should be around 300-400 ohms. (ZERO reading at 200 ohms setting, BUT, at 2M setting, I get 0.001)
CDI
Use Ohm Meter High Scale About 200-K
1) Positive lead on BLUE wire and Negative lead on BLACK wire should read infinite (no activity) I get 0.4.
2) Positive lead on BLACK wire and Negative lead on BLUE wire. Should be about 130-150 K-ohms I've got 0.3.
3) Positive lead on Spark Plug wire and negative lead on BLUE wire. Should read between 135-155 K-ohms. I've got 10.2.
Switch to Low Scale 20K
4) Measure between Spark Plug wire and Black lead. Should be about 2.5 - 2.7 K- ohms I get 9.7.
So, I get zero spark, if not MAYBE a minor spark here and there but technically zero.
Was running great for the last 300 miles.
Thoughts?
Thanks much!
Chris B.
bad coil 0 at 200 ohm setting tells the story.... the 2M setting is reading humidity.....0001 is nothing
Hiya His, I had similar problems all of a sudden and ordered new cdi and mag coil. Worked great for about 10 minutes and cdi failed. I have since given up on the chinese electrical components once I found a thread here by Rohmell called "roll your own cdi". I don't know how to link back to it for you but searching will bring it up. I have spark up the kazoo now. Was inexpensive and fun to make. I am also winding my own mag coil now, see "roll your own magneto" by Impression. More fun. I have seen the light and I shall never return to oem electrical hades. Best of luck to you.
Cheap 6 buck meter... they have a coupon for that meter FREE when buying a additional item. I have (4) meters, (2) 25' tape measures and (3) flashlights from them.
http://s982.photobucket.com/albums/ae309/Ron-Becker/Harbor Freight fliers/
