Just got my GT5 a few weeks ago (used) an have been trying to get it to run right ever since. It was running really rich when I got it, I swapped out the CNS carb for an NT carb (that did nothing except stop the horrible gas leak from the drain tube). I swapped the plug for a champion L86C and later a  NGK B6HS. Re sized the main jet to .065mm and have moved the needle into various positions, to alleviate the running rich. After all of this without a load the engine revs high, but as soon as I put a load on it it bogs down and is not accelerating past 5-10 mph (and still running rich), to go any faster I have to peddle to desired speed (somewhere between 15-18 mph as I cannot pedal any faster) and kind of try to cruise it to maintain speed (sometimes it will actually decelerate) I have also re torqued the head bolts as well. I'm at about 4500ft and the ambient temps are 65-85 degrees F. I'm at a loss here and don't know what else to try.
http://motorbicycling.com/images/smilies/Waa.gif
