You seem very knowledgeable of these bikes, I wanted to ask you about the roller on the chain tensioner. One side should have the bolt go through while the other side should have a round cylinder bearing protector and then another flat washer on top of it correct? I've been tightening the nut and bolt on it and seems like the more I tighten the harder the roller turns. Is this something normal or am I doing something wrong?
This motor has been broken in approximately 3 months now. I'm running 32/1 ratio and have never cleaned the carb or air filter. As far as I know, there are no airleaks. When I get home today I will tear down the carb and give it a good clean. My NT carb is very basic but seems to be working very well. I've heard nightmares on the CNS.
On the carb, I don't have the NT carb and haven't had one apart in front of me, so I can't give specific help, but....
If the carb has a main jet (large) and a pilot jet (small), pay special attention to the pilot jet when you clean the carb. My bike was running rough like you describe at one time, cleaned the carb, same deal. After fiddling with all sorts of stuff I pulled the carb apart (CNS) and removed the pilot jet. It is very tiny, only thing I could find to fit through it was the metal wire inside a cheap garbage bag tie (strip off paper, use bare wire). First poke through I could tell it was clogged up, the jet is so tiny it clogs easy and carb spray or compressed air might not be enough to clean it out (cause the hole is so small). After I cleaned my pilot jet the low end was so smooth and nice, it was like a miracle!
I'm not even sure the NT carb has a pilot jet, I know it is quite different from the CNS carb, but if you see a small jet and a larger jet, clean that smaller one good.....
You might also try searching the forum for threads about rough low end with the speed carb, or start a thread and ask other riders that have the same carb for advise.
Sorry to hear about your problems wit the CC.
If you have a steel crank, you can cold bend the ends to clear the housing, I would bend both sides so that they are even. I take the crank off and stick it into a vice and put a pipe on the end for leverage and bend them that way.
If the crank is aluminum, you would have to buy a wide crank kit.
Which cover is hitting? If the 'big cover' is hitting, then your manual clutch is sitting too high on the clutch shaft taper ( rare, I have only seen that once).
If the 'small' cover is hitting, then your centrifugal clutch is sitting too high on the crankshaft taper (more common).
In either case, remove the clutch and Dremel the hole to slightly increase its diameter, so that it can sit lower on the shaft. Go slow and constantly test fit the parts.
In one extreme case, the CC sat so high, I had the CC off and started the engine (it had a pull-start on it) and while the engine was running, I held a file to the spinning end of the crankshaft to thin it down a wee dab.
Hello all,
Every time I cruise at a low speed, my engine or clutch seems to be very jerky, my whole bike jerks. Does anyone know how I can solve this problem? Any suggestions would be much appreciated.
