case reed means your going to have the reeds mounted into the case under the jug, how you going to do that. sure you don't mean piston port reeds. which has been tried many times and dosen't work with these engines. not enough transfer ports in the cyl. the reeds end up to far away from the cyl. and you need to port the piston skirt in just the right way.
tried it many ways and it never worked well.
Wow!!!!!! Look how far we've come!!!! You guys are geniuses!!!!
