happyvalley
Motorcycle engines also have longer cooling fins to allow that.
A forced air cooling system generally has shorter fins to make the whole assembly more compact.
They are matched to the task required.
Yup, what he said.
Anyway, it's amazing what people will do in the name of aesthetics to something that works well as designed.
Sitting here looking at the HF and Predator engines, while it really does look a whole lot better with out the shroud and helps cut down on the lawn mower look, my wanting to remove the shroud is more that I want them to run as cool as possible this time of year and it just dawned on me, more with a lower profile engine then the Honda/clone (Clonda? snork), it also shields the head from the muffler...
MSRFAN, how did you thread the shaft to get a retaining nut on? Also is it left hand thread? Working on a thing and want to cut off both sides of the shaft a bit and am not sure how to secure sheaves on both sides.
As always, great builds!
Well this is a bummer then. LOL
Ran the HF 79cc in 100F at idle for 15 mins with and with out the heat shroud. It ran 7 degrees cooler with.
Underway, ran cooler with it off. Test ride one way with, was about 7 mins and 7 back with out.
I used an inferred thermometer and am gonna retest using a wired gauge. It was hard to read as the numbers jumped greatly. But am not putting the shroud back on other then for testing until next winter.
i think you would be well served to remove them.
