Are these engines designed to use gas that has ethanol added? Or do I have to use non-ethanol gas (which is more expensive here)?
The earlier Walbro carbs used a rubber based pump/valve diaphragm, the ethanol plays havoc with these. The composite versions, either light brown or purple/blue are ok with ethanol. Anytime you can avoid ethanol, do so!
