HOLY CARP THAT IS A MONSTER. The price is certainly right on it. I was thinking the harbor friend for the next build but I'm going to look into that one.
cannonball2,What can you say, but thats just killer! I can see my next project now, I have a full suspension MTB gathering dust in the garage. Not anything exotic like that one, but a good start. What was the problem with the stock exhaust? I wanted to use it on the Cranny but it interfered with the belt. Looks like it would clear on your bike, a deflector would keep it off ya. My goal was to use the engine out of the box.
The real trick was flipping the steel mount around to get the offset I needed, hole sawing a 1/14" hole which was then opened up with a band saw to allow the mount to fit around the front frame tube. I could have run the engine bolting it directly but it would require the use of wider angle to mount it and the bolts on the left side may have not cleared the angle vertical, so I just modded the stock mount. This engine is so compact that height is not an issue in a standard cruiser frame if the mount is modded like mine.Cannonball2,
I'd like to see close up pics of your engine mount.
Did you retain the Lifan engine mounting plate or remove it to reduce height & use the bolt holes for engine mount holes?
In-frame could be on my list of future projects & I'd definitely use another Lifan 2.5
-Lowracer-
It was possible to have pedals, this is a loose interpretation of the Popular Mechanics power bike from the 50s. Floor boards were part of its charm. The Grubee pedal set for the G4 kit from Kings would have had plenty of width. The Lifan is actually narrower than the HS/G4 engine/trans. Should be no problem to juggle things around a bit for the pedals. I have a G4 set up on another bike with the above pedal set, they are the widest I have seen.Cannonball2,
Wow, you really got that thing in there just perfect.
I dont think I would be able to do that!
I really like it.
If you went real wide on the bottom bracket axle, do u think you could get the pedal option too?
-Lowracer-
