simonsmurf
i have nutted it down to the cam and piston arm ceasing up i pulled off the cylinder and head to find slight surface rust on the arm i preceded to try and turn the engine over using the flat screw under the gearbox cover it took a bit of crc and oil on the cam to arm joint i eventually got it turning however this is supposed to turn very easy and freely it requires about 15 -20 foot pounds
is their anything i can do short of dismantling the whole engine to get at the cam.
thanks
thanks
