v brake adapter
beentryin
im trying to find out were to get the v brake adapter that bolts on.ive seen them but cant seem to find the post with a link
Plus the arms and pads
I thought it was a great idea till I started adding everything up
There's one for $9.99 below it that could adapted, but that would probably cost you over $10
But one thing I have noticed , as hard as I try to find them there are no good cheap brakes and the linear pull brakes are the best I have found in traditional pad type brake
I got a hold of a junk bike with V brakes. They had tabs to mount the brakes on. So, I just cut them off and welded onto my fork.
Terry
Terry
I was thinking that the same could be done with that $10 plate
But then you would still have to buy the brake pads and levers
Here.s another way to go ..
Buy the braze on adapters here:
FRONT CANTI BOSS WITH 7mm OFFSET single cut :: SMALL PARTS :: BRAZONS-SMALL PARTS :: Nova Cycles Supply Inc.
They're $1.31 each
Read Sheldon Brown's section on brazing on the adapters here:
Installing Cantilever Brake Bosses
This might help you if you can find someone to weld or braze these on for you, other than that, you're buying the adapters from Dan's Comp.
By the way the $9 dollar adapter they is for the x brakes (900's)
Good luk,
TiM
yeah you're right about that plate and I like the bosses
It wouldn't be any cheaper for me,cause i don't weld but it would look cleaner
I wont scrimp on brakes at all but I can't afford to put them on every bike for people that want $300 budget builds
Any bike I build for me will always have the best brakes I can manage to shove in it
I was day dreaming the other day about a bike with a dual pull brake lever on both sides of the bars
One would be connected to a set of drum brakes on both front and rear and one would be connected to a set of disc front and rear, plus it would still have the coaster brake
Get a set of Avid Mechanical disk brakes with 203 mm rotors. You will never ever need any thing else. They can throw you clean of the bike if you just wanted to try to. There fade feel and over all user adjustment is flawless. They work perfectly in the rain too. I am a big guy and their pads last me easily up to 7000 miles so far.
do they have weld on mounts?
No they don't your metallurgy has to come into place here and you make your own that is what I did. I simply locked the caliper into it proper place spot welded mine in then welded them in more good er. This bike weighed a bunch and I as well the brakes worked awesome!!
v brake adapter on my CranBrook
I just got through installing the V brake adapter on my huffy cranbrook. I had all of the brake[sram] parts laying around the shop. Aside from buying the adapter all I will need to buy is the noodle. Its got to be better than the crummy caliper brake that I had
Re: v brake adapter on my CranBrook
Night and day
I just built a second Point Beach. The first had the typical caliper brakes, which stopped OK enough
The second has the linear pull brake and the first time I hit them, pre motorization, I was thrown forward in the seat
i went with the disk brake on the front.got a bracket from venicemotorbikes installed it and it bent and destroyed my rotor so i took it off and used it as a template to make one out of a thicker piece of metal it turned out good after spending more money on a new rotor
