NO-NO! Your $0.02 cents are priceless!Ok, This is just an idea but:
With Go-Peds I always used to loosen the coil screws, place a paper business card between the flywheel and coil, then turn the flywheel so that the magnet pulls the coil on to the card, tighten bolts, remove card, and whalla! Near perfect magnet/coil gap!
Now I know you would have to cut/machine mounting slot instead of holes, but that wouldn't be too hard.
This is just my $0.02 and this probably isn't even what you're looking for but it's worth a shot!
Oh,Yeah there's tons of high tech methods.on ther VW's we used two cardbord thick for the plugs and one thick for the points,every plug came w/feeler gages
regurgitated?Oh,Yeah there's tons of high tech methods.
What-ever works!
Was that match book cardboard or corrogated cardboard?He-He! Kip.
[email protected]
That's neat thanks for the info!Kip.Thexton 404 Ignition Spark Tester with Adjustable Gap - Toolfetch.com It has a plastic shield [insulating] and a built in chart!
This is the cheapest and most accurate tool for the money IMO. I used this very tool for a great many years in Automotive.
A great many of the test light looking gismos are very deceiving.
What other-side the out-side?I agree,with the spacing thing ,but wonder if the other side of the C shaped coil needs the distance to be even
regurgitated cardboard?Kip.regurgitated?![]()
Soundedfunny from over here at the moment. lol.regurgitated cardboard?Kip.
[email protected]
I have actually used notebook paper before. lol. I have motors still out in the streets running with over 200 thousand miles on them. I prefer plastiguage 98% of the time tho.plastigauge is cheap and very cost effective when doing an engine build, we gave a demonstration in class there is 2 to 3 thousandths bearing clearance on the crankshaft, we plastigauged it and that is what we came up with by the book 2 to 3 is good, we removed one rod bearing and installed a piece of notebook paper on a display engine, we also measured this with a dial caliper to 4 thousandths, the engine would spin by hand when the cap was torqued the engine was locked down. so 1 thousandth of an inch will bite you every time.
It was funny,or at least we thought so?Soundedfunny from over here at the moment. lol.![]()
From engine hard to turn over - Third Generation F-Body Message Boards
plastigage - Google Search
I think it's a combination of the whole deal!You mentioned the rotor not centering/loose on the shaft ,is there a lot of play?,how did you center it?,,,or where the washers the main culprit for the out of balance?
Fix................. Fix.................. What Fix? -EZ
I don't fooollooow yooouuu!Kip.er im lost not that hard for me realy but wtf? dooo yooouuu hav a timing light? sure if its flat it wont vibe but youv seen these things i want 4 or 5 deg advance under load wile running determind by vackume right?
