I'll have to check it out. I didn't even know it was just a dust cover. I've never worked on a bicycle crank before.My moutain bike has something similar on it. I just went outside and stuck a flat blade screwdriver in it and popped it off, it's just a dust cover of sorts on my bike. There is a regular bolt under the cover.
I appreciate that. New ones don't cost much anyway though.u might need a new or a good used set of bearings there. man if ya was closer i would give ya a set i have just laying around in my ole parts box lol came off a wreck bike i found awhile back. had a good crankset on it.
Thanks, I can use all the help.Yes , you will need to either purchase a Shimano BB Tool or take the frame/bike to the local bike shop Park Tools http://www.parktool.com/category/bottom-bracket are usually reasonably priced. They probably even have them at the REI where you bought the BB.
ocscully
I'm not really aware of much except I've been trying to unscrew it for a few hours now and so far it hasn't budged. I'm trying to turn the top of it toward the rear of the bike. It's the one on the right side you know?You might try using a good punch and a hammer? You are aware that the cup has left hand threads? If you have no intention of ever using it again It appears to me that you might also be able to get enough bite on it with a pipe wrench.
ocscully
I couldn't find a piece big enough last night. I'll be making a run to the hardware store in a little while.maybe a piece of flat steel across the center like a big screw-driver and a cresent wrench(I know ,They are susposed to be called adjustable wrenches)
