Black_Moons
Hi, I have an intresting problem, my 2 stroke once I finaly got it running, idles low AND high, Altering beween low and high again slowly over 5~10 seconds, and back to low again over the same period of time.
Build info: Brand new 66cc engine, CNS racing carb, Eclip on 2nd to bottom of needle, Slightly advanced porting for the intake (Just so the intake is fully uncovered at TDC) By triming the piston skirt. Using a baffle/cat removed exhaust.
Checked for intake leaks by spraying some carb cleaner at my intake manifold setup, No apparent change in RPM.
Right now the idle mixture screw is all the way in for it to idle decently, Otherwise it only runs with the choke cracked open a little.
Also the cylinder started smoking heavily.. I think the paint was never cured, Seems the cylinder got hot pertty quick, within 5 mins or so...
Running 16:1 or so fuel for break in..
