DAX now has the Rear Mount system in both Friction Drive and Chain Drive. All made in USA and made from Alloy !!! This Totally new Bracket makes all other rear mounts both Friction and Chain Obsolete , old fashioned, old school..... This Bracket is Copyrighted in its design and Patent Pending. It is the only of its kind !! American Engineering at its best !! Designed and manufactured by Howell Labs USA copyright protected Patent Pending. IT is fantastic !! If you currently have a Friction Drive and wish to updated it, or change over to Chain Drive, this will do it !! At only $39.99, this bracket is the start to a whole new world of performance Motor Assisted Bicycling !! The Steel version designed by Howell Labs is also great and shares some of the same design traits as this new R1 bracket. The differences are as Follows:
1- Super Light weight 1lb 3oz. Compare this to the steel that weighs 4lbs 5.5oz. Wow!! This is Fantastic !!
2- Dual Holes for Locking posistion.
3- 4 holes for mounting are radius cut to allow the rotation of enigne mounted to it for up to 10 degrees of rotation. This is fantastic !! As we all know that most 4 strokes need to be level as possible in order to prevent a hydraulic and damage to enigne. With the ability to rotate the engine up to 10 Degrees full swing, you can get the posistion of the engine closer to perfection than ever before !!! And.. At only $39.99 and made in USA ! This is hands down the biggest advance in rear mount technology to date !!! Here are a few pics to wet the appetite. For more, go to the web site bicycle engine kit, bike engine, bicycle engine, bicycle motor and check them out !!! Get em while supplies last !!! DAX.. Engineering that just makes Cents !!!!
Pics are coming ~~~
Pics are coming ~~~
