Yes. Bring a tool kit in case your bike breaks down lol!
As long as you have the chain aligned right and your oil is the right level it will give you no problems. Before each ride check for tightness and for chain tension sometimes it may stretch. a 1/2 inch open end wrench is all you need to adjust tension.
And with all bike kits make sure you stop and give your engine a rest every 2 or so hours.
I weigh in at about 270. Colorado has some hills so Duane hooked me up with a 48 tooth. It definitely has more bottom end now which is what I desired compared to my 44 tooth. Top end is lowered but I don't ride fast anyway. At my 15 to 18 mph cruising speed my engine is churning at an RPM that gives me more power overall anyway and I pedal less now on them hills.
And I bought a plastic canteen at the army/navy store for just over a buck. It's the same material as my tank and it holds a full tank of 1/4 gallon of gas. I hang it on my handlebar. So now I don't worry about running out of gas. When I do I just fill her up with my canteen then I'm good for another 40 miles till I find a gas station. Then I fill up my canteen. It usually runs me a dollar.
The guys at the local station knows me already.
