You may think this is an old movie you've seen before called, "The Leaping Tuna Air Cleaner", but this is the sequel and is bigger and better and shinier and is not for the china girl, but for the 4 stroke Greyhound engine. They do have things in common, for instance they smell alike having started life as tuna fish cans, but as you can see in the photo, this baby is bigger and mucho better. Anything is better than that honker of an air cleaner that comes on it. A big rectangle of plastic. When I saw a picture of Jim Davis Corvette build with that cool Whizzer air cleaner on his I knew I had to do something. So the same high technology comes into play with this one and the price is right.
You'll need the big size tuna can and a can lid of the same diameter. I went to town this morning for hardware and stopped in the grocery store for air cleaner supplies.... the can of tuna, a big can of krautand a stainless steel pot scrubber. Around five bucks and you get to eat the contents.
Open the tuna can in the same was as the smaller version using a small punch (ice pick will work) to punch holes in a circle to open the can. Don't use a can opener since you need that big lip in order to close it up again. Look at the pictures and you'll understand. Connect the dots with a small knife and tack hammer, going from one hole to the next. I cleaned up the roof edge with the dremel tool and a grinding bit. You can use the intake manifold gasket as a template on the bottom of the can to determine the bolt holes and the opening for the carb to take in air. Drill the holes to size and try it for fit, being sure you have room for the choke lever above to clear. Mark the spot where the breather tube is going to go.
(cont.)
(cont.)
