a rather odd way to mount a strimmer/weedwacker
nathandance1996
I've just bought a strimmer and found a good way to mount an engine with friction drive,
it combines the advantage of front wheel drive a rear wheel drive, you have the shaft moving along the bike frame from the front (overhanging the front wheel) down to the tire with friction drive, you don't need to change the strimmer in any way so it's quite a good idea for commuting
edit_preview.php
cvlt1 brflg scratg
So you mount a wheel instead of the trimmer head. Would only work with the geared head trimmer. But the geared part is not at a right angle to the frame and not square with the tire. Maybe have the shaft and motor go thru the frame on a angle to compensate for the drive wheel not being at the right angle.
it did not work as the flexible shaft couldn't cope with the pressure, does anyone know how to build a bike with a strimmer engine??
Hey Kevin, It looks like its dangeling but it's proven itself pretty solid. I've used it successfully on 3 or 4 different projects.
The first bike was my daughter's 20 inch bike. That's where it was proven to be reliable. The kids rode the daylights out of that thing for 2 years, till they wore out the bike. Used it on several other projects, never had ANY trouble with the engine 'cept for a couple of carb rebuilds
I'll re-post some more pix in a while, my net runnin slow right now
Beyond the engineering involved, I wonder how the bike would handle with a frame mounted engine in front of the handlebars. . . Good or bad it'd have to be a unique experience.
Wayne, your setup is awesome to say the least! It's the perfect way to use the clutch and not have the engine at a 90 degree angle. I'll be looking forward to some more pics. Is that setup hinged so you can get the roller off the wheel?
Thanks Kevin
Yes it's hinged on a single 1/4" bolt,with a beam clamp holding it in positon. I never refined it enough to make the hinge operable with controls.
Here's more pix, but the first one in the other post has the most detail.
