bpr6hs same?
JG88cc
15
San Diego
I talked to a motorcycle shop about it. He said the only difference is that there is a resistor at the bottom to burn away the oil and prevent foul. I don't know if that helps, but if you have experience let me know what happened!
2door
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
Listen to Pablo.
Resistance plugs and wire are intended to reduce electrical interference with critical electronic components of today's cars. Originally resistance wire was introduced to eliminate the static 'buzz' you could get from solid conductor ignition wire in car radios. As the electronics became more sophisticated the need for a way to protect it from high voltage Rf interference became more essential, thus the introduction of resistance plugs and wire. Our little engines will run on resistance components but there is no need for it...unless you can't hear the music on your I-pod.
