Hi all, I am in the process of breaking in my 2010 Grubee Gt-5 66/80cc engine. The first time I started it I took it pretty easy varying the throttle range and not going over 15mph. I did the same thing the second time I started the engine and ran a little better as expected.
Now I am having trouble with the engine running. When I release the clutch, the engine wants to run but when I give it gas it dies. And if I don't give it gas it dies. If I assist the engine by pedaling it will stay on. While i'm pedaling I try to give it a little gas and the engine bogs down and dies. Tonight I got it running for about 7 seconds while keeping the rpms above idle. I can get the engine to run only if I pedal assist. What is going on? The engine wants to run!![:-|| :-|| :-||](https://motorbicycling.com/images/smilies/Waa.gif)
I used the recommended 1:16 gas mix for break in. I have the CNS carb too. I have heard there is a sweet spot for these carbs. "From the posts Ive read the sweet spot on the mixture screw is 1 to 1.5 turns out from all the way in." Should this be done even on break in? I have not messed with any of the settings at all.
