Electrical Guru's Needed , Thoughts Wanted - AC To DC
I just want to check and make sure I am doing this right cause Ive never done it to a MB only a dirt bike.
This is my plan.
White wire from engine to a regulator/rectifier combo to a battery to power lights. 6volts from white wire will charge the 6v battery.
Here is my setup :
Wiring Pigtail
6v Regulator/Rectifier Combo
6v Battery
The yellow wire coming off the reg/rec combo has me confused. The instructions in the pigtail picture say to run the yellow wire to lights or a light switch right ? But then it also says this :
These instructions are for a lifan/honda engine and obviously I dont have a yellow wire coming from the engine.
Where do I run the yellow wire coming from the reg/rec ? Back to the white wire ? To my now DC headlight ? Tape it off ? Where do I send the excess voltage so it can be delivered back to ground ?
This is my plan.
Here is my setup :
Wiring Pigtail
6v Battery
NOTE!! the yellow wire coming out of the reg/rec never has it's own power it just "T's" into the yellow wire that comes from the engine's stator wire, that then goes to the headlight dimmer switch it takes excess voltage and delivers it back to ground. thus the regulator part of the regulator/rectifier...
