timboellner
I don't quite know how many miles I have on my HD shift kit from SBP.
but I think the front chain ring and the 10 tooth sprocket are starting to wear. (500 miles or so )
It's starting to jump chain on the right jack-shaft to freewheel sprocket.
Even after tightening it, not too tight, not to loose, checking sprocket alignment,
I still get the chain jumping off 3-4 times in a 20-25 mile ride.
It's not skipping or slipping, just jumping off now and then.
The freewheel has some play but it's not sloppy.
How many miles have you guys put on the shift kit and have you needed to replace sprockets?
How bout the bearings?
It seems the 36 tooth sprocket shows less wear.
I just got done replacing the chain tonight and will see how it does in the morning.
I think the standard 10 tooth with the 44/36 gearing is just about right for my bike but I may try
the 11 tooth just for kicks.
I love the kit and would never build another bike without one.
I haven't needed to peddle from a dead stop yet. Giddy up bee-och.
TIM
TIM
