Yes. I think they are called 'Skewres', in short little off-set eye bolts you put on both sides hub bolts before the hub nuts, and a stay that cups around the end of the frame chainstay like this.
In short very cool cheap little helpers, especially when chain matching with no tensioner.
Your local bike shop should have them.
That bike by the way is a Grubee GT1, it comes with them as well as a hub mounted drive sprocket.
i have the 45degree front to back drop outs ..the torque from the drive pulls the hub loose ...any one know how to set up a device to prevent this from happening.
i am not sure i'm following you on the grease issue? what does that have to do with a tight fit?
