Just an idea...
Why not look into the Grubee GT1 or GT2 bicycle?
It should fit. Theres videos out there from australia i think.
I tried to find the link for the video. I will post it if/when I do find it.
BTW...![]()
Wow I just noticed... i'm a senior member!
The few...the proud...the senior members
(i'm trying to be funny here)
Firebelly cycles sells a mount for the worksman and the 4 stroke (Im assuming the 49cc) Check it out. I cant get a link directly to the worksman mount but click on the button above this picture. Firebelly Cycles What do you think? I sent them an email with questions last night.
Pat
i mocked up a 4 stroke for the worksman and saw it was going to be a lot of work to fit it in there. you would need a wide crank set to clear the motor, but also the motor is going to be setting where the pedal crank sprocket needs to be, can't off set that or the chain won't line up, if you looped it you would need to cut out the bottom bracket and move it behind the seat post like on the old board trackers, if you did that then a 4 stroke should fit. i used my worksman for a morini build, cut out the lower top tube and made mounts to fit the s6s in there.
