I doubt it. As it is now, the motor is mounted perpendicular to the frame so it oscillates side to side. Pics in another post in this thread. The motor somehow needs to be mounted horizontally or close to it. The aftermarket motor plate doesn't really allow this. The original Ezip mount is horizontal.If the rear triangle was flexing do you think adding bracing 1/2 way foward toward the seat tube would help?
Yeah, the Curry runs cool compared to the hub. At 36 volts, the Curry puts out some torque and pick up can be quick. The hub is still slow off the start and needs the pedal assist if I want to get up to speed quicker. Once there, it keeps going. I'm guesstimating with both, I'm hitting between 30and 35 mph on the flats. Good enough for me. Hills are way easier as well. I just can't do it with all that stumbling, though. I'm going to try the Curry on the PB and see how it works. Maybe different bike? I dunno. If both motors did that stumbling, chances are it'll do it again. <sigh> Try anyway.The 36v runs fine in the friction drive I run. I think the currie motor will take the excess without heating, I can not say for any others. I have a hut for 250 24v I run at 36 it has a nasty sound when it runs but it seems to run okay. I just never use it. I don't like hub motors.
Hmm. You thinking this particular controller may be wacky? Didn't even think of that. I have 2 more. Maybe I'll try one of the other ones tomorrow. Come to think of it, seeing that 2 different types of motors did the same thing. The only thing in common was the controller and batteries. The battery part is pretty straight forward. What else could an sla battery pack do? LOL Thanks Deacon. I'll give it a try. If it is bad, I won't be able to get a refund, but TNC will probably be alright with an exchange.Have you tried that with a different controller.
Ah, good point. Oh oh. The only throttle I have left is off the Bladez scooter. A heavy duty looking, lever type throttle. Problem is it uses different colored wires. Red, white and black instead of the usual red, green and black. Hmmm. Nah, looks like it's wired different to. Red can go to red, but the other wires are reversed on both ends. I'll figure it out somehow.The only other common feature that might cause it would be the throttle. If you are using the same throttle, I would try chainging that out if the controller doesn't do it. All the electric throttles are crapolla in my opinion. The thumb throttle has done the best for me in the cheap throttle dept. The twist ones are gone in couple of months it seems.
That reminded me of a friend , who has a son with great passion for toy trains...Boy got huge amount of locomotives and various train cars and tracks...Only , he never got to play with it , my friend took over ("He - meaning his son - is just too small and he will broke it...")Hey, I could take the throttle off my daughter's Razor electric dirt bike. That's all I need. She'll come home and go, "Daddy! Why is my electric bike broke?" and I'll say, "It ain't broke. That's what the pedals are for. Go pedal that thing around."
