My 20's Style Touring Build
twowheeledfox
First off sorry for a new thread but the old one was cluttered and OT.
First a quick overview of my build- if you are not interested just skip to the questions (I do need help on these please).
First pic is of my build at the moment.
I used a standard, mid-size 26" rigid ATB frame, stripped of stickers etc. Rear wheel was trash and went to the scrap yard. Front wheel is a decent aluminum/ steel spoked assembly and will stay on the bike.
Brakes: unknown as of yet
Wheels: unknown as of yet
Seat: Vintage Viscount springer (makes it look like an old BMW R36 seat, look it up)
Bars: Chrome risers for a comfortable ride
Pedals: Made to be a copy of "starter pedals" used by motorcycles of the 10's and 20's, using a tiny front sprocket and large rear sprocket the ratio isn't good for much over 2 mph but works great as a backup starter and gives it that vintage look.
Motor/acessories: 2-stroke 68.5cc slanthead kit, "silver" paint job that looks okay, using kit clutch and brake levers, grips, electronics, tank, etc. Has pullstarter.
Gear: Large rear reflector, hillbilly-made headlamp (turn signal case from an old motorcycle, sawed off the rear cap, inserted a cheap LED flashlight, clamped the light to the case and used some scrap aluminum to mount to the bars), Bell toolbag with full toolkit, rear rack with 2 gallon spare gas can, motorcycle mirror off a Honda CB350, walmart digital speedo, standard tires and tubes.
Question: Would an external gearbox, Non-jackshafted, work on of these china motors? Here's my idea (See 2nd and 3rd photos for my dummy setup): Using a flipped front derailer from a bicycle, right under the motor's lower chain output. Put a lower sprocket such as a 44 or 48 in the derailer's lower gear position, and a higher sprocket like a 36, 38 or 40 in the derailer's higher position. I already thought about chain alignment but a properly spaced 2-speed shouldn't do too bad (let me know if otherwise of course). See pictures for true detail.
The goal of this whole thing is to put together a 2-speed gearbox for the stock China kit that is cheap and can be made using regular bicycle and hardware parts. 2-speeds is just right for these motors, one to start off in/hillclimb and one for cruising. That way 30mph is doable calmly and the clutch won't fry every time you take off from a stop. It would also work for stock HTs, make things a bit more universal and make the list you tell a new MBer to get easier, ie motor kit, lights, trans.
Would really like some input on this, again see 2nd and third pics for the dummy setup.
If you are brave as ****, you can make a 2 speed "shift kit" for cheap:
Put a mountain or road crankset on the left side, and your regular crankarm on the right (the old square taper style, parts are cheap). Make sure they are the same length, and adjust for pedal symmetry using the bottom bracket cups or washers on the pedal threads. . Run a single gear on the left side, to the motor, with a heavy chain to prevent skipping/slapping.
This will be a permanently motor-assist only setup. You will be forced to pedal with the motor or disengage the clutch/kill engine to stop the pedals, so it would be wise to use really large right side front chainwheels like a 56t and a 48t. At the very least, a 42/52 or 43/53. You can pull the clutch lever to pedal & shift the front crankset on right side. Use a BMX freewheel on the back. Simple enough.
But you will be able to exceed the motor bicycle speed limits in some states as you are pedalling full time, and there is rarely any speed limit for bicycles but what is posted for cars.
The idea of shifting by derailing the chain so far from the sprockets will be a problem, and there is no idler or derailleur shown to take up the slack.
It is good that you are trying to think of ideas about the bikes though. Sometimes a good idea may come from the strangest places.
Would a tensioner possibly work as an idler? Was thinking spring loaded but that would flip the chain off when shifting- maybe, if I am wrong a spring-loaded tensioner would be perfect.
Still mulling your other idea over, hmm..
I think what you should do is buy a 2 speed moped factory made, but if you really want a 2 speed bicycle, find out how some users here made bikes with a pocketbike motor and an infinitely adjusting comet clutch. (like a snowmobile but smaller).
If you try my idea though and it works, make youtube videos. This ought to be neat. Imagine cagers having a heart attack seeing a guy pedaling a huffy 35 mph without sweating hahahhaha.
Re: My 20's Style Touring Build--- me like old style
me like old style
Brakes: V-brakes front. No rear brakes as of yet. PITA to adjust them but they are very powerful.
Wheels: front 26" aluminium, rear unknown as of yet
Update: Found a two-speed sprocket set from a 90's MTB crank. Removed the crawler gear and plastic protector and got a surprisingly sturdy 48t-39t sprocket set.
They are connected closely to each other and will be mounted on the wheel like a typical MTB's freewheel gears would be, except of course on the left side of the wheel and using the rag joint and bolt mounting system that comes with the chinese kit.
The diameter of the hole in the center of the sprockets is too small to fit on a standard wheelhub and will need to be made larger, the same size as the 44t that comes with the chinese motor. Would a machinist be required to do this?
Once the center hole is large enough, it will be fitted over the hub, mounted on the wheel and the issue of chain alignment and tension will be next. Some sort of spring-loaded tensioner would be necessary UNLESS the difference in sprockets (8t) is small enough not to require high tension and the stock tensioner can be used, putting a middle ground between higher tension (larger sprocket) and lower tension (smaller sprocket).
Ah crap... just found of my frame is misalinged, the motor chain leans to the right when mounted straight on the frame and measurements confirmed that it is about 1/2inch off balance. If I get a new frame and fenders I can't afford to try out the 2-speed setup. Although reading through the archives on here it appears 35mph is possible with a 44t, it was substantiated (videos by a senior member, not the "OMG 40MPH LOL11111" types). However, it does free up money for fenders! This could be a quite vintage build, maybe something like a 1910 Pope Motorcycle?
Alright that last post was rubbish. Sorry.
Okay, here is the situation now- I have switched to another frame and am still having problems with motor alignment. It leans to the left just slightly, and the bottom end of course has more acute lean making the chain somewhat out of alignment (when the chain is strung straight from the sprocket outwards, it points rightward at about a 15 degree angle).
I am not comfortable building it like this for many reasons, safety, power transmission and aestetics to name a few. Anyone else had this problem?? The frame I am using is very common, a typical hardtail MTB frame.
Help please, and thanks.
Mine does the same, to a small degree. It would be hard to place a 44t cog right next to the chainstay and not have it saw the frame. Have you tried putting an assembled bike wheel and cog in the frame to test it?
I did right before I closed up for the night, the chain bends a tiny bit. I don't know about the strength of these chains or the master links either, I will try to figure out a front mount mod tommorow, maybe that will fix it.
The master links are strong, but the engine driver cog sometimes might bind on it.
If you put the wheel on the bike and put the chain like you are actually going to ride it, then see what it does. It may not do it when pulled tight. Walk the bike to test, and "start" the bike without spark plug to test for chain problems that would affect starting.
Decided to paint the frame today while it was apart, going for the vintage motorcycle look so I chose flat black.
I would highly reccomend Krylon Satin Black (indoor/outdoor). It went on well and gave a smooth flat finish. Painted the fork and it looks excellent.
I need to respoke my rear wheel, I have the spokes and new hub, but does anyone know if Sheldon Brown's tutorial on wheelbuilding is sufficient for a motorbike application? It seems pretty thorough but I had to close up for the night just as the rims were cleaned and prepared to be respoked.
Clutch arm question... while connecting the clutch cable to the arm, I see no way of securing the cable. Most of these kits have a small screw at the tip of the arm that secures the clutch cable, but this one just has a flat gap (the size of a typical flathead screwdriver gap) and no screw or mechanism to secure the clutch cable. How is this meant to work?
Secondly chain question, I have the tensioner set up so that the tensioner wheel is facing inside the frame, is this correct? It seems to work. The chain, from motor to tensioner to wheel, is not perfectly straight, the motor leans a tiny bit to the left, the wheel is probably a tiny bit out of true, etc. I don't want a teardown again, these minor variations won't kill me or the bike right? It seems I have seen too many haphhazard, "throw an unmodded china motor on a regular, unmodded bicycle" situations work out well, and they almost definitely had wheels out of true, badly mounted motors etc far worse then my situation.
re: wheel building. Lace it up like a conventional 36 hole 3 or 4 cross wheel. Remember to brace the spokes across each other at the broadest intersection, just like a good mountain bike wheel. Nothing fancy necessary or desireable for this application. With thicker spokes, you might find your task a little more difficult as you can not readily flex the spokes the same way. A cheap flathead stubby screwdriver that is filed narrow to fit in the spoke holes, will speed up your work.
re: clutch arm. Mine came with a little brass part that slides over the cable, with a securing screw to hold it. I am not sure about yours, but I bet you can make do with a conventional nut and bolt, esp if you hacksaw the bolt a little or drill through it for the cable.
Yes, you can put the wheel toward the inside of the frame. Make sure it is really secure and keep it tight, or it can rotate into the wheel, esp upon pedal starting. See my thread on motoredbikes.com Chain Tensioner Idler related accidents.
You can keep cable ends from fraying by soldering/tinning, by heat shrinking, by dabbing with JB weld, or in a pinch, Super Glue if the cable is new and perfectly clean. Also, old spoke nipples can be pinched on as cable ends.
