if i boost compression by shaving the head will that make my top end rpms higher or lower. im wanting to increase my top speed and this is the only thing i havent tried yet. wha tdo you think?
metalliatic,i know it will make more torque, so it will take off easyer. but will it make my top speed higher? once the engine tops out at a highets rpms it can, i cant go any faster, right? im running a stock slant head now and i has thinking of milling off a little off the bottom.
This isn't true.Removing a little material will do nothing!
Jim
Pirate Cycles.. but Manic Mechanic makes themWho sells the high comp. billet head????
Cool.....it's designed for the engine with a more noticeable dome... if in doubt, you could buy the pistion and a set of rings from pirate cycles along with the head and it should all work out
Thanks...Just got one of the billet heads. A piece of art! Now I am wondering if I shouldn't order the piston and rings from Pirate Cycles also. All my motors have been the same except the one el-cheapo that I sold to another guy. Can anyone post pictures comparing the dome of the piston so I can tell if I need to replace mine or not? Better yet would be a measurement of the hight of the dome. I will measure mine tomorrow when I put on my new head.
Is`nt it cool the way it wakes up the motor like that??? It just wants to pull to the moon if you let it....??? I haven`t been able to use ALL my throttle YET......No, I thank you! I read your reply after the fact. I swapped my chinese slant head out for my new head during my lunch hour. Tested it out a little on the two mile ride home. Still good power low to mid but then this thing just takes off revs and pulls like it never did! Definately some of the best money I have spent on this bike. Keep building them because as soon as people start talking about them everyone will want one!
