Hub Diameter Help
AaronF
I need to order a sprocket adapter from Manic but no one answers? So I guess I'll order online.Does anyone happen to know the inside diameter for a Shimano C201 Hub? I came up with 1.115 inches for the hub and the spoke flange came out to be 0.0283 inches.I'm not sure if I got an accurate measurement with my cheap digital caliper.So if anyone knows or could measure the same hub for me that would great!
Sounds more accurate than what I came up with! Thanks. I was just wondering,if I went with a sprocket mount for the Modus 8,can I use a shim with his sprocket adapters?
If your measurment was acutally 1.115 the modus won't work on your hub. The Modus is for hub 1.181-1.187 inches.
Yeah I don't know my measurements to well lol.I just thought about using sheet aluminum to shim.My caliper was actually correct though at 1.115" Thanks.
Just throw the rag joint on till you get the adapter. If you did not order yet call Pirate Cycles and see if they have one in stock. In the wind is better than no wind.
