Hub Diameter Help
Discussion in 'Motorized Bicycle General Discussion' started by AaronF, Apr 2, 2010.
  1. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    I need to order a sprocket adapter from Manic but no one answers? So I guess I'll order online.Does anyone happen to know the inside diameter for a Shimano C201 Hub? I came up with 1.115 inches for the hub and the spoke flange came out to be 0.0283 inches.I'm not sure if I got an accurate measurement with my cheap digital caliper.So if anyone knows or could measure the same hub for me that would great!
  2. K.i.p
    K.i.p New Member
    Nov 8, 2009
    340
    Probably 1 1/8" and 1/32" , 1.125 and .031 respectively but don't act on my opinion.
  3. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    Sounds more accurate than what I came up with! Thanks. I was just wondering,if I went with a sprocket mount for the Modus 8,can I use a shim with his sprocket adapters?
  4. psprat496
    psprat496 New Member
    Nov 22, 2009
    161
    If your measurment was acutally 1.115 the modus won't work on your hub. The Modus is for hub 1.181-1.187 inches.
  5. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    Yeah I don't know my measurements to well lol.I just thought about using sheet aluminum to shim.My caliper was actually correct though at 1.115" Thanks.
  6. chopperjoe
    chopperjoe New Member
    Nov 15, 2009
    130
    Ive been waiting 5 weeks now for my adapter from the Manic, getting annoyed. Good luck
  7. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    I heard the sprocket adapter and sprockets are going to start being machined next week.I can't wait weeks for a adapter either..
  8. chopperjoe
    Nov 15, 2009
    130
    Just throw the rag joint on till you get the adapter. If you did not order yet call Pirate Cycles and see if they have one in stock. In the wind is better than no wind.
