Hi Jared8783,
Although you don't like the drive cover, it is at least SAFE! The EZM guard covers all the moving parts and removes the danger of clothing entangled in the moving clutch. Our cover also aids in protecting the belt & clutch from weather related failures [slippage due to rain, etc] We are currently working with NOVA plastics in Norfolk, VA to fabricate belt guards and hope to have our logo embossed and improve the cosmetics slightly. Our current cover is one of the thinnest available [width does matter, LOL] and makes riding more pleasing.
With the help of the major belt companies [Gates, Dayco, and Carlisle] we have just released production version #5 with a higher belt transfer rating. It is also important to note versions #1,#2, #3, & #4 worked without design failures and most can be upgraded to version #5 for increased power transfer [version #1 is manual and can't be upgraded to later versions] The engineering departments at the leading belt companies have shown us ways to reduce the HP loss to approx. 2%, thus allowing 98% power transfer.
Sadly the same can't be said for the CVT drive systems, as they are known to EAT power [up to 38%].
We did some research and testing on the CVT systems and found them bulky, wide, and hard to keep in adjustment. Considering the Honda 50, HS 50, and even the HF 79 greyhound produce 2.5 HP or less it didn't seem wise to give up any power to operate the CVT drive.
If you want an example of CVT power losses, extra weight, and WIDE profiles, just look at the Whizzer NE-r motorbike. Any NE5 belt driven Whizzer with the automatic clutch will out perform, produce almost twice the gas mileage, and is MUCH lighter than the CVT equiped NE-r.
As far as your comments about the EZM "i know they are not cheap", guess again! Looks like we are less expensive than some of the latest offerings from several companies.
BTW you can order the less expensive Q-Matic drive [was designed & tested on the Honda & HS motors] and we will rebate you the cost of the cover if you want to fabricate your own cover [we are open to any ideas to improve our product].
Now back to the original reason for this post.........
Although I like the Honda motor, it just isn't worth the difference in cost over the HS motor. I am currently using both motors on factory proto-type motorbikes. The Honda was aquired in an EVEN trade for a HS motor, because the owner found the HS to be faster and much easier to install on a motorbike. The HS is faster on top end, and usually starts easier, however the Honda apppears to have a little more bottom end power. Either motor will deliver enough durability and power to get the job done, therefore it is just down to brand loyality.
If someone likes Honda, then buy the Honda, if price is an issue then buy the HS, both are great choices.
Have fun,
