Who needs common sense and personal responsibility any more????
That's why they have lawyers and law suites.
fast"it's your fault"eddy
...Aircraft lock nuts did the trick for me ......I've adjusted my tensioner ONCE....in almost 2000 miles......correctly done as stated by 2Door....they cause nary an issue......Lowe's had the two nuts and bolts I needed for a whopping buck and a half......Bairdco, I used a piece of inner tube between my motor mounts and frame, not to kill vibration but so I didn't mar up the frame, so far I've had to tighten the bolts (after break-in) once in about 1000 miles. The chain tensioner thing I can see where you are coming from, I do use a tensioner but I only use the one that mounts with 4 bolts, I have seen the 2 bolt ones and frankly they seem scary to me. Its good to see your looking out for your fellow rider, thanks for the post![]()
We do have Dick & JaneBack when I was in High School we had a required reading for English ( but it applies to this day )....a copy of Thomas Payne's " Common Sense "....a Hero from the Revolutionary War.....But since you reside in Canada I'm not sure you're familiar with it .....Read it....it's quite enlightening......
Salty
P.S.....that's *suit*....not *suite*....a suite is a room or rooms in a hotel....
