Wide Engine Mount Spacer
Kevron99
Guys I need a 2 inch wide mount spacer. Does anyone know what vendor sells this? I need a wider mount to space into my front mounts. I have check all sites that I know off including e-bay they all measured to 1.5 inches only. Desparately needs help. Any suggestion is highly appreciated. Thanks
for 35 bucks, Jim at creative engineering had a fantastic mount set up. He's on the side bar to the left
I'm planning a road trip first week of Feb. for the exact mount you speak of Paul....I'm 2.5 hours north of Jim and figured I'd pay less for gas than I would shipping since I'm also going to be purchasing his sprocket and adapter as well as his intake....I spoke with Jim on the phone this week and he said " come on down ! ".....his mounts are the bomb !
Salty.shft.
Gas Bike sells a universal mount that will fit 99% of the frames out there ....I bought one myself and it works just fine.....www.gasbike.net
Salty.shft.
Yeah...Thanks Salty. But all I need is a spacer since there was an inch and a half gap between my motor and my custom front mount from Ridleys.
You're welcome Kev and sorry I can't be of more help....Have you considered a machine shop fabricating one for you ?.....a small piece such as that shouldn't be too pricey......
Salty.shft.
Kev,
Do you mean 'wide' or 'thick'? I consider the width to be the distance from side to side. The bolt centers are only about 1 5/8" inches so you couldn't open up the saddle, semi-circular portion to 2". If you mean the thickness, from the engine case to the seat tube center, then fabricating a 1/2" spacer shouldn't be difficult. A piece of scrap aluminum should be easy to find or even your local Ace hardware has 1/4" aluminum that you could stack to give you the extra 1/2" you need.
In the past, I have used flat aluminum stock literally glued together to the correct thickness and then cut/filed to shape. (I was 15 and Honda wanted some ridiculous money for an axel block on my 125) I think all I use was hondabond, and it worked great for five racing seasons.
