I bought a grubee skyhawk kit with a 44 tooth included. Can a 36tooth from another supplier fit the existing washers and stuff, or can I use another washer/bolt/cog kit with this engine, as long as it takes the wide 1x1 chain?
You could email Bike Berry and ask.I got my motor from Bike Berry and all looks well, fast shipping. But their site doesn't show a smaller cog. Maybe they sell a larger engine cog.
Otherwise most other suppliers sell 36T, zoom have 40T flat sprockets. (I have one here, not fitted yet.)
I can personally recommend zoombicycles, dax or Rock Solid Engines from experience, otherwise try the sponsor sites on the left, or, for fancier stuff, try:-
MANIC Mechanic Parts.htm
...Steve
There are significant variations in hole position. Donuts and crescent washers are not always interchangeable among sprockets. I have 3 different incompatible types.yes pretty much any sprocket for use with the 9 hole adapter and 415 chain will work look at the sponsors on the sides of this page theyll hook youup im sure
very true, i forgot to mention make sure your get the corect hole number and size bolt holesThere are significant variations in hole position. Donuts and crescent washers are not always interchangeable among sprockets. I have 3 different incompatible types.
When reading install instructions I have seen both, cut and do not cut 2nd rubber washers. I decided the do not cut sounded correct. What I have not been able to understand is the wording "Tighten Bolts", how tight is that? 12 ft lbs - 30 ft lbs or ???? - think I am getting anal in my old age.
Or maybe they are dumping stock from 2001. Others like DAX and BGF have them and they are cheaper and fit.I don't know what the 5hole 36t would go to, but maybe they don't drill them with 9 holes, so no one can sue and say they sold a kit that went too fast, or maybe they think clutch wear will be increased with the small cog..
