In theory, two 6 volt generators in series should make 12 volts, but in reality it doesn't work that way. I'm not clear on why, it's just what I've heard.
TheE, maybe but even if you gained voltage, you would lose current. So it would go from 6 volts and .5 amps (3 watts, like most 6volt generators) to 12 volts and .25 amps. still 3 watts, but not really enough to do anything with at 12 volts. Maybe LED lights, but if you are going to go that far, you might as well use 6volt LEDs.
Just my 2 cents.![]()
12 volt generators for bicycles do exist.
i have had nothing but bad luck from wheel driven bike generators. according to others here on the forum it's due to the fact that they generally aren't made for the high RPMs these motors put out, and can effectively spike a 12v 6w generator up to 18v, blowing the lights out and even the generator itself. (I've had this happen no less than 4 times due to stubbornness.)
