Im not big on the thin smooth tires....My bike handles alot better with the wider tires....The tread on my tires are were there is always tread on the ground so there is no bumping and I dont get flats anymore....With the smooth tread tires I was getting flats all the time....I guarantee you'l notice it immediately- but do one thing, take both of the cruiser tires off first and holdthem in one hand and then hold the smoother narrow tires in the other-
the most difference is in the roll, but there's a lot of weight loss to be gained with other tires- cruiser tires are designed to ride on the beach without sinking in.
Hi all,I have a little problem.My bike runs great up to 22mph,but when I hit the 23/24mph mark my bike starts surging,the speed will jump up for a sec then back down.It wont go faster then 24mph.even if i go down a step hill at the 24mph mark it starts acting funny.is this called bogging?is my engine running to lean or rich?what do I do to fix this.thanks for all your info guys.Randy
I've found on my bikes that the 'surging' is from the engine being very close to being the right mixture but a little too much on the rich side. it feels like the bike is bogging & then it will get a little 'crisp' burst of speed, then go back to bogging... re-jetting a little smaller has always fixed it.
This is also how I know when I have the jetting right, it will run real crisp & clean with just a small bit of 4-stroking. (the little bit of 4-stroking tells me that it's not too lean!!)
Could it be possible that the smaller jet uses less fuel and allows the restricted fuel flow to "keep up", also allowing for the right mixture at the same time? (slightly too rich+restricted flow=surging) (smaller jetting+restricted flow=just right).
Nashville Kat,I just dont agree on the skinny smooth tires becouse with the wider tires I have better handling and control,also a tire with semi tread(tread always on the road with no bumming)keeps me from getting flats....When I had smooth tires I was getting flats every week,sence I switched to a beachcruiser tire with semi tread I havent had a flat in 6 months....TCAMS ZONIE:
I would advise consulting a local bike shop or two- my rims are alloy on a newer Micargi cruiser. The 26 x 2.25 were easily replaced by 26x 1.75. That's a gain of 1/2" in narrowness. But the new tires are smooth tread and weigh much less too. I was able to use the same tubes, ad the tires only ran $10 each- but then I've had a lot of experience changing bike tires through the years. Be carefull not to pinch the tubes if you do this!
The first thing you'll notice is how much easier the bike pedals even before firing up the motor. The motor notices the difference as well.
I also eventually put the 27 x 1 1/4" wheel on the front, which is even narrower still. But this usually will require another brake- a road brake with a sufficiently long reach, mounted through the center hole in the fork above the wheel. This brake is a Campagnolo road brake- I don't recommend because it took special boring of the center hole, and reaming of the sides of the brake to get enough reach.. The back one would not fit if I try to put a 27" wheel on the back, and I'd need a brake with a longer reach, because the center hole of the cruiser frame is drilled at an upwards angle for a fender, not a caliper brake- But the front brake really works much better than the original cantilever.
Recent photos and one from last summer, just after the first tire change-
