MY bad, I should have been clearer.
This is inside the cvt
The top numbers are the ratio inside the cvt 10 to 60 and in the next photo 10 to 30.
They are the action of the reduction of the cvt .
I could have used 1 to 6 for the start about 3,000 rpm when the clutch grabs to 1 to 3 which is the final reduction at high rpms for the cvt
The following is outside the cvt.
The output shaft of the cvt is a ten tooth sprocket feeding a 48 tooth front freewheel sprocket connected to a 24 tooth drive sprocket which feeds the rear cassette.
With the front peddlable jack shaft from a shift kit I can use the standard sprockets.
The engine is a gp 460 from Daves Discount motors with a 77 mm built in clutch.
bb88xx
With a tuned pipe good reliability . And will turn 11,000 to 15,000 rpm all day long.
The variator weights will melt in the 120 plus Arizona heat, I use cut down brass sleeves.
You may want to look at a mitusibishi 5 to 1 transmission for less maintenance.
I am .
Go here for cvt advise
CVT Q&A thread - GopedNation Community
Before you decide it is for you.
In town driving with traffic the cvt shifts for me .
I use the rear cassette for ranges.
I usually just use third, or fourth, maybe fifth.
LOL .
First will destroy the chain.
Second will climb a tree.
Sixth is for stupid downhill runs.
Way to fast for the bad roads here.
