I was wondering if anyone has tried this expansion pipe and what they're experience with it was?
thanks
Fat Cat Chrome Expansion Chamber - $49.99
thanks
What is the reasoning behind that statement?That thing will produce an incredibly peaky and narrow powerband, obviously designed by someone who doesnt know 2 stroke theory very well.
Thanks Foxie. I'm pondering modifying pocket pipes/scratch build vs hitting up SBP again. Your list pretty much sums up the Big Picture. A couple of these occurred to me when I saw the photo.1) the chamber is tiny
2) there is basically no headpipe
3)the baffle cone is not steep enough
4)The baffle cone ends in an abrubt wall, then goes to the stinger
5)there is basically no stinger.
curves and turns effect the pipe in absolutely no way. You can have three 180 degree bends in a row, and as long as your not actually crimping the pipe to impede the flow, the sonic resonance will happily follow the path. You can even have angled bends, that go in 20* segments or whatever.
Important things are keeping the cones and chambers cylindrical, and not flattened or ovaled in any way. Thats far more importatnt than placing bends in the pipe.
edit...
if your going to try to make your own pipe, the one piece that is absolutely critical is to make sure you have a straight, clean and smooth entry from the head pipe (which idealy should have a 2-3* taper of its own) into the diffuser cone. So when you weld the head pipe to the diffuser cone, go back with a die grinder and smooth the joint on the inside, make sure its all flush.
now youve confused me...Actually by curves I was refering to the shape of the chamber and transitions. With limited welding tools I'm wondering just how much performance is sacrificed by making it from stock mufflers parts which are dirt cheap compared to sexy but expensive pocket pipes. In other words very short diffuser exit and entry I guess.
For example would I expect one built this way to be half as effective in boosting torque/WOT compared to the SBP? I know pretty much what the difference is between bone stock and the SBP unit.
Excellent! Now we are both in the same boat!now youve confused me...
Well like I say... trying to use parts from stock exhausts which do have a rounded shoulder but nothing close to a real diffuser. I see versions of the Poo Poo pipe that do not appear to have a cone but still get rave reviews. Wondering if these actually perform or, like is common from over-excited hobbyists, just smoke being blown (sorry).hrmm... after re reading more than a few times I think I get what you mean. Are you asking about abrubtly ending the chamber with endcaps and such, as the stock pipe does?
Really you should be aiming for a 6-8* taper for the diffuser cone (7-8 for wider power band, 6-7 for a more peaky max output) and roughly double 12-16* for the baffle cone. Thats what will give you great results.
Yes. Your project was not only a work of art but I also suspect a real performer. To be honest though, considering how much work you put into it, and $30 plus, it makes more sense for me to just buy another one from Pablo and Jim.Mine was from a pocket bike, was cheap ($29 shipped) and was pretty easy to fab up. And it does work.
Cuts and joins for Kevlarr pipe: 1 hourThe satisfaction from making making it myself more then makes up for my hour of time.
