george_n_texas
What bolts seem to get loose and how often do you have to retorq em down. The instructions say every 50 miles that seems a bit extreme to me.
stay away from the red lable Loctite. It will hold anything but requires a lot of heat to remove the threaded fastener without doing damage
And what do you find not true about it? Red lable Loctite is a good product but has no place on a motorized bicycle. If you have evidence to the contrary, let's hear it.LOL! If only that were true.
my opinion on red loctite? it has a weird, sweet smell, and it's sticky, but it doesn't taste like cherries...
Do not re-tighten fasteners every 50 miles. That is bad, bad, bad information that has caused people a lot of trouble. You don't do it on your car, motorcycle or any other machine, don't do it to your bike. Engine fasteners such as intake and exhaust manifolds, head bolts, mounts, torque them properly once, then after the engine has reached operating temperature a couple of times check them but only to see if they need a slight tightening to be where they need to be as far as torque is concerned. Any machine needs maintenance and its sound advice to check things periodically but when you torque, then re-torque and continue to do that you will surely twist off studs and nuts. Like the man said, use a short (stubby) wrench and use discretion in how tight you make things. If you opt for a thread locking compound stay away from the red lable Loctite. It will hold anything but requires a lot of heat to remove the threaded fastener without doing damage. The blue lable is a far better option. Double nutting is okay and nylon lock nuts (nyloc) are good too.
Spoken by someone who apparently has little experience with the stuff..
Think about it. If you put a microgram of Red on a 3/8" bolt do you seriously think that bolt will be stuck forever? Even with "permanent" locktite slobbered all over, these can be undone with little effort. Assume we are using tools made of steel here, not plastic or wood.
These bike motors need all the help they can get and it would be great if "permanent" threadlock was really permanent. I have done literally thousands of nuts in the last 10 years and few required heat to remove. Don't hurt to go easy on it though because it is expensive.
Rock breaks scissors.
Scissors cut paper
Paper covers rock
But anerobic ester (plastic) threadlock does not hold steel. Not permanently anyway.
I typically do not enter into arguments but in your case I'm going to make an exception because you're comparing apples to oranges here. We're not talking about a steel 3/8" bolt and nut; we're discussing 6 or 8mm fasteners threaded into an aluminum casting which happens to be of questionable quality.
The stock nuts (including nyloc which are one-use only) never stayed put on my installs.
