Hi al,
So I got everything hooked up on my bike with no major problems except for what I would call a mid-size kink in my exhaust. With my wife filming (which may have been my first mistake), I made my first attempt to get the motor running. With no response, I realized that I hadn't opened the fuel valve (call it nerves), but it didn't get any better. I was getting a put-put noise, but it wouldn't fire up. After checking the forums, I tested my spark plug by leaving it exposed (I broke a chunk of one of my cooling fins trying to get the thing out) and riding in the dark. It produced a fairly consistent spark once I got going pretty fast. The spark plug also had traces of gas, so it appears that the gas is getting to it. I also opened up the clutch and tightened the flower nut to the point that if I hold the handle down it won't engage, but using the locking mechanism (which lets out a little slack) is too close and half-engages. So I'm pretty sure the clutch is not the issue. Where those were the two major fixes I saw on the forums I'm pretty stuck now. Someone mentioned that if there are dark splotches on the spark plug then it may mean that I have too much oil in my gas mixture. I think that might be the case, but I'm not sure. I mixed an 8 oz. bottle with 1.012 gallons of gas, so it doesn't seem like that would be the case.
Does anyone know what might be the problem? More importantly, does anyone know how I can fix it?
Thanks,
-Scott
Thanks,
-Scott
