What about the amperage pull from the 2 Cree led's...?
It may be too much for the system. I have one Cree now, and it robs
the power to the to other 6 volt lights when everything is wired parallel.
This could be because I wired the Cree light straight up with no resistor
at 6 volts. It lived...but not for long.
I'll go get that 10 ohm resistor and try it.
Keep in mind, I have not started this bike yet.
I am testing everything off of 4 AA 1.5 vdc Nimh
rechargeable batteries in a series to get
6 volts total, with 2500mA common.
So Everything should be in parallel, even for both the 6 volt Brake & Tail led's...?
(They Consist of Four Led's in a Series Each and are Very Bright...
just not as bright as that Cree led...that thing is amazing)
Your batteries are not doing their job. Or you are pulling a lot more current than you think. Set your DVM leads and display for amps, run it in series with the battery when all lights are on and the motor is off. How much current are you pulling? When your lights are wired in parallel, they should not rob power from each other. When wired in parallel, each light circuit is pulling current independently from the battery. Other circuits should not go dim unless the battery cannot handle the total current. I'm assuming that you are using wire of adequate gauge.
