New S T R E T C H....Micargi Mustang GTS
RedB66
I had to retire the red frame. It developed a hairline crack after about 1100 miles. I may be able to fix it. I transferred all the parts onto a chrome frame and added a chrome tank.
Bitchen' Nice.
Talk to us about the airccleaner connection.......what's the deal..............?
Bitchen' Nice.
The connection into the air cleaner is Nitrous. I connected the air cleaner by mounting 2 large (same circumfrance as carb) washers onto the carb and then mounted the rubber fitting from air cleaner over them. Tightened down with existing clamp.
Interesting that you've nitro'd the chengine - what performance increases have you noticed and how have you solved the lean-out problem ?
I love the frame, do you know if there is a UK supplier for it?
Jemma xx
These mounts were made from a Simpson construction tie and a chain tensioner bracket, I cut the lagre part of the tensioner to match the small part. The width worked out to go around the large tubes. I used rubber fuel line to cover the bolts bewtween the sections.[/IMG]"]
[/URL]
Another mod I did was to change the 44T sprocket to a 36T (not the motor drive chain) allowing me to lower the engine.
Very cool... I was going to buy a frame like that from Revolution Cycles and build one up... but stayed with my full-suspension MTB. Now I know what it would have looked like .... COOOOL !(^)
Just curious, where did the old frame crack ? Do you think this was the result of a bad weld or was it due to stressing the frame by mounting the motor on it (vibration etc) ? I'm curious to see if the new frame holds up. These stretched cruisers are indeed a sight to behold and I'd love to build one.....I just can't help but wonder if beefing up the frame a bit might be in order ? Your thoughts please ??
This is a heavy bike!! So my thoughts are that the gauge of metal used to construct it is sufficient. I had over a 1000 miles on the red frame and when I say crack in it....it is as though the weld just came apart. I can clearly see that the weld did not penetrate the two pieces bieng welded. I will keep you posted on this frame.
Thanks...I sure hope this one holds up for you. Absolutely stunning bike by the way, BOTH of them ! All I can say is WOW! They look extremely comfortable too....well, at least until you have to pedal up a hill without power LOL. Thank God for these little motors !
(c):ride2:You can also buy the GTS at Chubby's Cruisers in Cal. I have 2 of them in blue for sale with Robin/Subaru 4 stroke 33.5 cc friction drive kits. 30 mph & around 200 mpg! I bought these bikes new in July 2007. Indoors kept[except for riding] And in excellent cond. I will sell 1 for $675.00 954-985-4239 or 305-778-9539
What is it like to ride this bike? Do you lean over when riding or sit fairly straight up? Is it comfortable for a long cruise, say 15 miles?
These bikes ride very comfortable for long rides. We ride these stretch cruisers for hours at a time! And your not hunched forward but your kinda leaned back. I prefer the semi ape hanger bars, they really make you feel laid back on your ride. The Micargi's your replying about have been sold for a while now, but there are many moto bikes out there you can find to ride! If I can post, here's a pic of my latest ride, a Kustom Kruiser Slick Daddy. On this pic, I have'nt installed the apehangers but they make all the difference in the world!
