reg454
I want to point out first that Norman did a post like this before and I'm am doing this so I have a link to get to it to help people out.
I have read posts where people cannot get their motor running even though they have spark and it is getting fuel but they are encountering resistance and they motor will not kick over. This post is to help those of you out that are experiencing this problem and for those of you that have tightened the flower nut to the point where you have very little play in your clutch or you want more play and it being tighter.
Their are two ways to tighten the Inner clutch spring, the first is on the bike and the other is off the bike. I am going to tell you both way.
First you are going to have to remove you clutch cable from the clutch arm, Then you are going to have to remove the clutch cable from the Clutch guide you can see both in this pic.
Next you are going to have to remove the clutch guide and get an Allen wrench between an 1/8" and 3/16" and put it in that hole. Pic
You also put grease down that hole too. Lubricate the innards of the clutch.
Next make sure you spark plug is removed, and loosen the flower nut a little bit.
If you have the motor on the bike you can simply turn the rear wheel clockwise to tighten the inner clutch spring. (I don't have a pic of this one) You will notice that when you are turning the wheel the Allen wrench will grab on something (you want it to do that, that means it is catching the nut on the spring to tighten it), The tightness of the spring depends on how many revolutions the sprocket on the motor turns, a few times around should be good. It all depends on how tight you want the clutch.
If you Motor is off the bike or the chain is off you will need to do as above as far as removing the clutch cable and guide you will also need to remove the clutch cover.
You will need a pair of channel lock pliers or a pair of vise grips. In the pic I am using vice grips but the pliers are better. With the pliers grip in between the sprocket teeth and turn clockwise to tighten it just like before.
You will notice that you clutch is a lot tighter and you can now tighten or loosen the flower nut till you find a place where it is good for you.
You can reassemble you motor now.
Best of luck to everyone hope this helps you out.
Thanks again NORMAN for the post you did before don't want to steel your cred.
