How is the Super different from the regular version?
What does the manufacturer do to the Super to make it super?
Better carb?
Porting?
Is it still the same displacement?
Exactly what changes have been made that makes 1/2 HP more?The Super Titan "Titan Supers" are in. These are a souped up Version of the TITAN XC50. These Factory Souped up Titans make 1/2 hp more than standard Titan and also come with 1 year Warranty. The Standard Titans are great and have acquired a Name and excellent reputation world wide. I expect the Super Titan XC50S will do the same. I am not completely sure what the factory has done to make them so powerful and I could only guess since I have not had one apart. They are telling me that Stroke and bore have been altered as well as compression. All these changes add up to more Power !!!
Engine Type Air-cooled 4-stroke OHV
Bore x Stroke 41.8 X 36 mm
Displacement 49.4 cm3
Net Power Output* 2.1 HP (1.6 kW) @ 7,000 rpm
Net Torque 2.0 lb-ft (2.7 Nm) @ 4,500 rpm
PTO Shaft Rotation Counterclockwise (from PTO shaft side)
Compression Ratio 8.0:1
You did not answer any of the questions about the Super Titans engine specs?The Honda and Titan Standard are rated at 1.8kw 2.5ps. honda gxh50, gxh50k1, 2.5hp (50cc) engine specifications . That is the same as 2.5hp at 7000rpm they are posting. If you do the math, you get 2.41hp. So.. I am not sure what is going on there.. For increased reliability, Addtional oiling grooves have been added in critical areas as well. These engines are so reliable , I have not had to take one apart yet to see all the internal differences there are. Displacement Spec is the same. In a drag race, the Super Titan will run away from the Honda GXH50. Enjoy the ride...
The question was not about the Honda GXH50When I get a chance, I will procure and then post more detailed specs.. I can tell you this.. the Super Titan XC50S will run away from the GXH50 .. It says.. Bye bye ...... Enjoy the ride..
So you are saying that higher compression and better porting enable yourHi skyl4rk ,
Porting is better and compression is bumped up. Also has additional oiling grooves. I can tell you this.. It will out run HONDA GXH50. Super Titan is Super !!! Enjoy the ride..
I do not have any more specs or Details to offer other than those specs posted on my website.
4 stroke ohv
1cyl
48.8cc
3hp
2.75 Nm torque
Max RPM 7500
Air Cooled
CDI ignition
length 274mm
Width 226mm
Height 354mm
Weight 12 lbs
If these specs do not suffice, you can always call me at 303-459-2780. That is.. If you are serious. Call me Scott.. That way we can... Talk..... And with VOIP and other mediums of propagation, the talk will be as you put it.. Cheap.. lol
4 stroke ohv
1cyl
48.8cc
3hp
2.75 Nm torque
Max RPM 7500
Air Cooled
CDI ignition
length 274mm
Width 226mm
Height 354mm
Weight 12 lbs
Proof is in the pudding. Here is a report from Ron. He already had a friction drive kit he bought from someone else and only wanted to up grade his engine. So.. He bought a super Titan engine only and swaped it into his setup. Here is his report..
Hi ....
Thanks for getting me the new muffler to replace the shipping damaged one. I got the new bike assembled and motorized yesterday. The performance of the Super Titan is AWESOME. It outperforms the 2 stroke 69 ccs (skyhawks and several other no-name brands) I've used for several years (using larger 48 tooth sprockets). I'm astonished how much power this motor has.
It accelerates uphills, the torque is very strong, super quiet and VERY smooth running. I'm still breaking it in....so have yet to run it hard. It cruises at 20-24 with no effort using the larger roller.
I'll be ordering a couple more of these engines soon. Both my wife and son want to scrap their 69cc 2 strokes for this engine!
I made one mistake when getting the bike set up for initial testing. I had the throttle cable too tight and when I went to push the drive roller system down onto the wheel it reved. Before I could lift it off and or hit the kill button ... ended up with zero miles on a 30 dollar, kevlar re-inforced tire...LOL. The power is impressive and could double as a wood router..LOL!
Back to me now: It Sounds like he had a little trouble with a throttle cable. O yea.. And FEDEX slammed the box and crunched the muffler. Had to send him a new one. anyway...If you want to contact this guy, let me know, I will ask him if it is ok to forward his contact info to you. PM me if you want to know. Titan and Super Titan are Top Shelf engines. Let there be no mistake about it. Titan and Super Titan are the best factory 50cc verticle 4 stroke engines with clutch pack available at any price. And I have been dealing in enignes like these since the 1970's. DAX.. Engineering that just makes cents !!! Enjoy the ride..
