| Sponsors
| Our Forums | | | | Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines. | can't find an answer then ask here someone may be able to help!! Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. yeah i did the mix correctly, i took 4 bottles of 50:1 and put it in a gal to run ...  | |
09-24-2009, 11:14 AM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: FLA
| | re: can't find an answer then ask here someone may be able to help!! yeah i did the mix correctly, i took 4 bottles of 50:1 and put it in a gal to run the breakin. the motor has an hour and a half of ride time already b4 itwent out. it ran well, first day 25 mph, next day 28.5mph . wen i try to start it, it wont start, but if i hit the killswitch it wants to start but black smoke and the oil/gas comes out near the top. ima try to check the head out and ill keep ya posted.. i just dnt know wut it cud be, i appreciate all the help. |
09-24-2009, 11:49 AM
| | re: can't find an answer then ask here someone may be able to help!! well i looked at the head gasket, it looked fine. i re tighten them down, seemed it helpd a lil bit. but i tried startin it up without the ground (green wire) and it wont start, tried it on choke as well, still kept the same noise.
i put the ground back on, and tried to start it wile hittin the kill, and it tries to start.
if i hold the kill down and give it sum gas, itll stay runnin, lol, probaly not gud for it but im testin waters right now... is it the magneto????? burnt up??
thanks
If it tries to start while holding the kill switch on you have it wired wrong the kill switch grounds out the ignition to stop the engine. If the mag is fried it will not fire at all. wire the engine up with the black from the mag to the cdi and the blue from the mag to the blue on the cdi leave off the kill switch and also insulate the white wire so it can't ground out. make sure you have the spark plug gapped at 0.020 see if it will fire up
I'm not following your mix ratio how many oz. of oil to 1 gallon did you use? You should use about 4 oz. of oil to one gallon of fuel.
09-24-2009, 10:29 PM
| | re: can't find an answer then ask here someone may be able to help!! the oil is 2.6 oz. on the bottle is says 50:1 one bottle to one gal makes 50:1. i mixed 4 bottles to a gal. 2.6oz x 4 = 10.4oz. wow i didnt know it was that much, is that ok? it ran fine the day i put it together, didnt smoke or anything, ran it for a few hours that day. it could idle. the wiring was right from the day i built it, cuz it ran. i noticed my ground was kinda tachy tho, (loosish) did that possibly fried it out??? i just tried just havin the blue and black connected but it didnt start. then i tried with the white on red/yellow as well, but nothing. then the ground as well, but nothin, it will only try to start when i have the ground connected and hit the kill switch wile tryn to start it. but sounds like its bogging, have to gas it up a lil to keep it runnin, but wont run on its own, i never gapped the plug, i just put it in out of the box, but like i said, it was runnin fine for 2 days..the plug is kinda wet, wen i wipe a paper towel on it , its kinda brownish, but not too bad..i checked the carb ect. idk wut to do but to replace the magneto, but am not sure at all, but i appreciate everything norm.
thanks |
09-25-2009, 03:01 PM
| | re: can't find an answer then ask here someone may be able to help!! well i just finished cleanin the carb and mixin the gas correctly (lol) but it still wont go....  |
09-25-2009, 10:30 PM
| | re: can't find an answer then ask here someone may be able to help!! try a clean new spark plug gap it at 0.020 if you can look up the riders in Fl that are close to you they can help you with hands on help. You might do an intro post and let the guys know where you live then you will know who is close by to you and willing to lend a hand.
Norman
09-26-2009, 12:31 AM
| | re: can't find an answer then ask here someone may be able to help!! it was the magneto!! i overlooked the little wire that is soderd to the frame of the magneto, it was burnt, disconnected, i resoderd it and it works!!
thanks for your help!
Good for you finding the wire disconnected that one is a hard one to find.
Norman
09-26-2009, 03:02 AM
| | Motorized Bicycle Newbie | | Join Date: May 2009 Location: Canoga Park
| | re: can't find an answer then ask here someone may be able to help!! my engine was working fine all day but out of nowhere when i tried to start it it wouldnt i checked all the visual obvious things but nothing
it will spin but make a winding noise like a generater radio the turn over once and keep winding the pop once then keep winding
what could be the problem? |
09-26-2009, 08:49 AM
| | re: can't find an answer then ask here someone may be able to help!! is your clutch slipping? |
09-26-2009, 08:09 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Illinois
| | re: can't find an answer then ask here someone may be able to help!! i need help on how to assemble the clutch on an 80cc RAW motor. i have the clutch so that it is parrallel with the bike and then when i pull the lever at the handlebar, it goes about 45degrees perpindicular with the bike. the back wheel wont spin by its self at all, it just sounds like the piston inside is moving when i force it. i hope that is clear |
09-26-2009, 10:24 PM
| | re: can't find an answer then ask here someone may be able to help!! motor bicycle clutch
see if this will help you with the clutch | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:57 PM. | | |
