Kioshk
I've been breaking-in a new X80 engine for the past two weeks. I have it on a 29"er with a 56T sprocket. I have an NT Speed with a 70 jet, needle at the richest setting, intake ported and right against jug, plus a 6 plug. Running a 25:1 mix of Lucas semi-synth with 20% castor. @ sea level, and ambient's been about 32F/0C. Head has been showing a consistent 360F neighborhood on flats, and around 480F after short moderate hill climbs. Have seen just over 500F (!!!) @ plug after a couple of steeper climbs ("only" about 410F on rest of head). Engine is BLACK, and I use an IR gun to monitor temp. I have verified that there are no air-leaks. Plug chop shows medium gray ashy tip; head/piston inspection shows black piston-top, slick shiny cylinder/piston skirt. Bottom-end clean and oily. My cargo and I weigh over 300#. Engine runs great' and I hav no performance complaints, I just dread seizing a good engine. I'd be more comfortable knowing the engine's cooler and the plug is chocolatey. I suspect I should try larger jets, but should I be _urgently_ concerned? Am I already overly concerned? I've been putting about 30 miles a day on it. I have a modded stock exhaust (removed baffle/cat and replaced with a Chore Boy...better than stock flow). Actually receiving a Voodoo X pipe today, hoping it may improve temp as well as performance.
Thoughts and/or advice please! I treat engines like puppies; I'd hate to realize I was abusing one.
