Okay with the small rear wheel the crank arms drags the ground. I need to shorten them and I'm not holding a machine shop. I also honestly don't care what it looks like. So why can't I just:
1. Move up about two inches and drill a 3/8 hole through the alum crank arm. It is still solid metal there.
2. Run a 3/8 x 4 inch bolt through it.
3. slide a 3/8" ID galvanized pipe nipple onto the bolt
4. Use lock washers and double nuts whatever it takes to lock it down tight.
I hope it would give me a solid peg two inches farther from the ground. On my hub motor bike it shouldn't be a big deal that the pedals don't rotate.
Or should I not lock the nipple down and let it roll over the bolt as I pedal.
Whatcha think.
Whatcha think.
