Where to buy 26 inch freewheel with aftermarket sprocket and possible drum brake ??
TommyGunBC
I'm looking into getting a new rear wheel for my Huffy Cranbrook build so I don't have to worry about the cheap coaster brake hub and want a aftermarket sprocket and possibly drum brake .
found this at spooky tooth but it looks like they aren't in business anymore
http://spookytoothcycles.com/compon...age=vmj_ace.tpl&product_id=461&category_id=52
don't want to spend a arm and leg either , pirate cycles has some but are out of stock and says the sprocket is ALA carte but they want to charge you for something that the description says on the house aka Ala carte I guess someone there failed french :)
Re: Where to buy 26 inch freewheel with aftermarket sprocket and possible drum brake
your best bet may to be find the wheel you want and then add a shimano nexus roller brake. i can get one for $60 plus ship.
i'm not expert on this particular brake but it looks like it could fit any wheel.
This might be what you are looking for:
Grubee HD Axle Wheel with Solid Hub For 2 Stroke Motor
http://www.pistonbikes.com/product-p/gruhdaw.htm
http://www.bicycle-engines.com/Freewheel-Sprocket-and-HD-Axle-Kit-w-Brake.html
Freewheel Sprocket & HD Axle Kit w/Brake
Item: 4S-CDS-*FHDKIT
Our price: $49.99
http://custommotoredbicycles.com/brakesdisc_brake_v_brakesdrum_hub_brakesdual_brake_leverbrake_parts
HEAVY DUTY SEALED BEARING BAND BRAKE HUB, hub takes 12 gauge spokes.HD hub assembly with 202 sealed cartridge bearings.Hub parts as shown,non freewheeling sprocket for pedal start engines.$65.00
BAND BRAKE ASSEMBLY WITH THREADED HUB
http://www.ebay.com/itm/BAND-BRAKE-...300958592476?pt=US_Brakes&hash=item461287addc
i got one of those hd wheels came with the bike i got off craiglist i weigh 220 and with extra weight of rack bag etc it runs great , the band brake works it not that good or its me that cannot get it to work Right as there's a screw missing , the the wheel itself is good,as you can see.
[URL="
