The stock straps don't fit. I will be using double sided tape as well. My top tube is about 3" from top to bottom. It is more of a blade than a round or oval tube. Suggestions?
Who's the man TOM? YOU da MAN! Thank you.The kit tank studs are 5mm X 1. Ace Hardware sells a part called 'rod couplings'. They are made for joining two sections of threaded rod. Buy four, thread them onto your tank studs then install the kit straps and use four 5mm screws into the bottom of the couplings. You'll need to determine the length of the screws after the tank is seated on the top tube and the straps are installed under the couplings.
Good luck.
LOL, Thanks, George.Who's the man TOM? YOU da MAN! Thank you.![]()
Oh, C'MON! Now you're just showing off!LOL, Thanks, George.
I've used this method on a couple of bikes with oversized top tubes. It works well. Your using double sided tape is also a very good idea. That way you don't need to overtighten the tank fasteners. They will suffice to hold the tank and the tape will help keep it where you want it.
Ive used a product made for seating auto window glass in the door channels. It's called, 'window setting tape' and any auto glass shop will have it. They'll probably give you a foot for free if you ask nice. It is about 1/8" thick and when wetted with a solvent like WD40, it becomes slippery but dries and becomes an adhesive that will hold the tank in place as well as offer some cushioning too. Hope this helps.
