I assume that you've got the clutch lever pulled in and the clutch is adjusted correctly?
And throw the kit instructions in the trash and adjust your clutch cable so there is little to no slack when the handlebar lever is in the engaged (unsqueezed) position. My guess is either, as Norm said, the clutch pads are stuck or the clutch cable isn't tight enough. A loose clutch cable is a common problem with first time builders.The clutches of these engines are usually a little frozen from sitting in a box for several months... Pull the clutch lever 'in' & use some force to roll the bike back & forth to try to break loose the stuck clutch pads.![]()
